Ace Bingo HELP!!!!
NJ
Ace Bingo HELP!!!!
Hi I'm starting a Bingo 20..Need some info from those that built this plane..Most important Is I'd like to know the weight..This one will be built for E flight..So I need to know the weight before I start, so I spec out my power system..
Thanks Dan
Thanks Dan
NJ
RE: Has anyone built this plane??
Hi All I guess I'm the only one that's ever built this plane..I know it's an oldly but goode.
I just thought some one out there might supply some info. on this project..
Thanks Anyway Dan
Thanks Anyway Dan
NJ
Hi All Where did all the old timers go?? I know the plans for this plane came out in 1994..Some one HAD to have built this plane??? This was a popular design back then...
Dan
Dan
Dan, I have an Ace 4-20 I converted to electric. I replaced the ply fuse with balsa. I just used the ply fuse for patterns and cut them out using 1/8 balsa I believe. As far as weight, I have no idea what the Bingo should be. My 4-20 comes in at around 35 oz. with battery.
I built a new wing last spring after a tree grabbed it several years ago. Don't know why I waited so long to build a new wing, but it flies great with a Hyperion 3014 series motor and 3S pack.
Also check in the glow planes forum. You may have better luck there.
good luck with your build. cheers jollyroger
NJ
I have an Ace 4-20 I converted to electric. Thanks for the info on your 4-20.. I E-mailed the designer of the Bingo 20..He said "IT" should be the same weight as the 4-20 which was 48 ozs or 3 lbs..I'm going with the lite ply sides..The last E plane that I built I used balsa for the fuse sides and it was a major PIA.. Your 4-20 sure came out light only 35 with battery..My battery and E motor comes out close to 16 ozs..
My power system for the Bingo is a Scorpion 3020/12 should get 300 watts at around 29 amps with a APC e 10x5..So at if the Bingo AUW is 48 ozs that comes out too 100 watts/lbs.. Should more then enough power for this plane..
Thanks Again Dan
PS did post in the glow planes forum with out any luck..
Thanks Again Dan
