heaviest plane you'd fly precision with a 50cc?
OR
I am wondering how heavy is too heavy for a 50cc. I have the Lanier Yak (my 2nd one) and am considering installing a DL-50 I have laying around. The first Yak has a zdz-80rv in it and it is actually almost severely overpowered. It is right at 18.2 pounds minus fuel and I have a real hard time finding the sweet spot for hovering. It either drops or climbs. I have tried several different props, several different throttle curves, but it's getting better. So, I was thinking for the 2nd build, I may just use the DL on it, since my other DL rips a 17 pound PW around almost like a foamie. Any thoughts?
My Feedback: (98)
RE: heaviest plane you'd fly precision with a 50cc?
I bought a Lanier Yak 54 from a friend, he had a DA-50r in it. He found it took almost full power to hover and could not pull up from a hover. I put a LS-100cc twin in it I think I have the power to hover, but I just started getting into 3D so I'm not good at it, but the plane will go out of sight vertically.
OR
ORIGINAL: soarrich
Yes true, if you build them box stock they're too heavy for a 50cc. I have done several lightening mods and I should be able to keep the plane right at 17 pounds.
My Feedback: (7)
my friend yak weight 21 pound dry with a DA 50
it did fly but it need more power than a DA 50 at that weight
the IMAC basic was the only sequence it can fly
so to answer your question as Pat Roy state 17 to 18 pounds should be the heaviest to fly precision with a 50cc
it also depend on the engine because for example
a bme 50 do not have the same power as the DA 50
It really does depend on the class. Basic and Sportsman IMAC do nothave any long uplines, with good energy management you can fly ove 20 lbs. In fact, a 20lb plane willprobably fly basic better than a 17 lb. plane, they tend to be more stable.
Above sportsman, you need to be able to hold sustained uplines while rolling or snapping, you won't want over 17 lbs. in those classes.
The best I ever did in IMAC was with a very underpowered plane. I had to spend a lot of time practicing energy management to be able to complete all the maneuvers, I think the forced extra practice made me fly better.
TF
TF
