Engine head gasket material
Old 09-03-2007, 08:10 PM
andy86na
Default Engine head gasket material
What do you use? I need to make a custom gasket.
Old 09-04-2007, 02:02 PM
arobatx
Default RE: Engine head gasket material
You can do one of two things here. Go to your local auto parts store, where you can purchase sheets of gasket material, where you can cut your own. Or, if you determine that the engine in question as enough squish clearance at top dead center, you can leave the cylinder gasket out all together and use something like Yamabond, to create your seal.
Chad
Old 09-04-2007, 03:25 PM
RCPAUL
The UC folks face this problem all the time since many use engines that parts are no longer made for. Buy a circle cutter and use the aluminum in pop cans.
Paul
Old 09-04-2007, 04:20 PM
andy86na
Thanks guys--I wa sure there multiple solutions here.
Old 09-04-2007, 06:03 PM
pe reivers
Pop cans will do but may be a bit hard. The alu foil that food trays are made of is much softer, and compresses very well.
