Solartex clear coating
Old 09-07-2007, 08:54 AM
Dr. Bellows
My Feedback: (7)
Dr. Bellows's Avatar
Default Solartex clear coating
I am flying a Balsa USA Eindecker with a Zenoah G23 that is spewing black residue all over my Antique Solartex. I was wondering what type of clear coating do you guys use on Solartex? I would like to use water based if I can and how do you apply: brushed or sprayed? Thanks
Old 09-07-2007, 09:18 AM
LesUyeda
Banned
Default RE: Solartex clearcoating
I used Behr water based polyeurathane on my Sterling PT-17, brushed, and it worked fine. I first tested the paint with 15% nitro to be sure. You don't have that problem.
When I made the new doors and drawer faces for our kitchen, I sprayed, and found that I had to use an extremely high pressure to get reasonable results (if I recall right, it was about 60#).
Les
Old 09-07-2007, 09:43 PM
Dzlstunter
I had good luck with Nelson Hobbies water-based clear. Gloss or matte is available. If you use the cross-linker, it is fuel proof. It went on very easily (as advertised) with cheapo foam brushes. It does everything as advertised, in my opinion.
Old 09-07-2007, 10:07 PM
Dr. Bellows
My Feedback: (7)
Thanks guys! I am testing right now Minwax water based satin polyurethane. I brushed it on with a foam brush. So far it looks great and didn't change the looks of the original finish.
Old 09-08-2007, 11:50 AM
Rodney
Default RE: Solartex clear coating
I have always used Hobby Poxy's clear epoxy but it is no longer available. However, Glasscote (spelling?), a Canadian company now sells the identical product under it's own name. I have also used the Miniway polyuethane but it leave a much softer coating while the epoxy is quite firm or hard.
Old 09-08-2007, 02:42 PM
Dr. Bellows
My Feedback: (7)
Thanks Rodney
Do you know how well the Minwax holds up with gasoline?
DB
