my t-rex spins too fast!!! help please
Hi guys... I am new with the t-rex 450..... everything seems to be ok, belt tight.... but when I try to lift.... it starts spinning to the left very fast..... what can be wrong???????? the belt is new, I checked if.... belt slipping, worn teeth on belt or gears and nothingggggggg.... it"s the 450 SE... all metal....thankssssss......
RE: my t-rex spins too fast!!! help please
Thanks vince.... it was that! andddddd... after 5mins... it went straight to the ground, hehehehehehe... it was too windy for a newbie cost: blades, the main grips shaft and I'll see what else........ I guess that it has to happen... but... why that soon?????
yes, first... I have a lama v3 and I have practiced many hours in the SIM.... I should be ok, but I wasnt
just take your time. dont expect to be able to hover on your first flight. these are a lot harder to fly than a lama
MI
you said you were a newbie, So there are many common "beginner" errors in your setup that could have caused the heli to yaw left.
1) gyro not installed or set up properly. ie. servo or gyro reversed. not enough gain, or servo throw, incorrect gyro mode, inibited in the radio.
2) belt twisted the wrong way causing the tail blades to spin backwards.
3) tail blades installed backwards. trailing edge first.
We need some picture or you need some local help. If its not sorted out by now.
OH
ORIGINAL: ronfurious
edit: of course I read your #1 option wrong and thought you missed it. Silly me for jumping to answer.
