Newb Q: What do I do with Foam in Tire
Old 09-16-2007, 04:56 PM
AresROC
AresROC's Avatar
Default Newb Q: What do I do with Foam in Tire
So I got tired of just drifting around the TT-01, and got some tires with thread.
The problem is, the set of tires came with a set of foam, what do I do with them? I tried the obvious and tried to stuff them in the rubber tire, than mount the rims, but there are tooooo much foam to fit them in. Can't I just leave the foam out?
The stock tire (smooth) that came with the TT-01 didn't have foam. I want to use the new set of tires on asphalt. (I also bought some CA Thin glue, don't know if I should use them...)
Please advise or point me at the right direction! TIA!
ID:	764004   Click image for larger version
Old 09-16-2007, 05:02 PM
drevil
Default RE: Newb Q: What do I do with Foam in Tire
Leaving the foam out will cause the tires to wear out much quicker and will affect handling. I usually put the foam in the tire and slide it over the wheel. It's not always easy but with a little effort it can definitely be done.
Old 09-16-2007, 05:21 PM
TIGER76
TIGER76's Avatar
defo worth it m8 dont glue those tyres til you have some in there helps balance the ride out better and like said saves tyre wear too
Old 09-16-2007, 05:55 PM
ohgrfreak
ohgrfreak's Avatar
Trim the foam to fit. A little at a time so you don't trim to much, you want it to fit fairly snug, but not too much that it will bunch up in the tire and make it lopsided.
Old 09-16-2007, 07:26 PM
AresROC
AresROC's Avatar
SWEET!!! In one hour I probably got all the tips I would ever need on foams for tires! THANKS!
Old 09-16-2007, 08:41 PM
ohgrfreak
ohgrfreak's Avatar
This forum has got to be the best on out there for RC stuff, I came here from an uptight forum, and people are so helpful here. I'm glad you're getting the help you're looking for!
Old 09-17-2007, 05:37 PM
AresROC
AresROC's Avatar
I DID IT ! [>:] I folded up the foams like pictured and squeezed them into the tire. The foam was in a cut strip form not a ring but it worked fine. Now if I can just neatly glue the tires on the rim...
