Did I buy the wrong pinion
Old 09-18-2007, 07:29 PM
Gado
Default Did I buy the wrong pinion
I bought a Pinion that was advertised to go on an RC18T
I have a Stampede with a 540 motor will it fit?
http://www2.towerhobbies.com/cgi-bin...?&I=LXJHT6&P=7
Old 09-18-2007, 07:36 PM
aer-wubby
aer-wubby's Avatar
Default RE: Did I buy the wrong pinion
Nope. Too small. RC18 is a 1/18th scale, which uses a 380 sized motor. The 540 has a 1/8th shaft, which is bigger than the 380's.
Old 09-18-2007, 08:36 PM
happywing
happywing's Avatar
If that's a stock motor, then you're probably out of luck. The motor that I have in my mini has a 1/8 shaft, so pinions are interchangeable.
Old 09-19-2007, 09:00 AM
Gado
Thanks guys
Well darn I just found this out
the Motor is a Method R which
Shaft Diameter: 1/8" (3mm)
the pinions shaft is
Mounting hole diameter: 2mm
