Vectored Thrust nozzle
My Feedback: (24)
RE: Vectored Thrust nozzle
Dennis, we carry two versions of a vectored nozzle. We suggest 4/40 (or the hanger 9 titanium) rods and ball links for linkage connection, both units already provide the attachment points for linkage.
My Feedback: (60)
Here's pics:
Video:
http://www.my87.com/video/rookie/seanrookie.wmv
Video:
Video:
Video:
NJ
Sean,
I am installing the same vector nozzle to my RookieII, but with a new Titan SE. I am wondering if your tube is bolted to the former or just tight aroun tthe turbine. When I install mine the wings of the tube set above the former due to the offset in the turbine mount. Also, is there a rule for the distance into the nozzle the exhaust should be. Looking at your it looks like you have back as far as possible.
thanks
Scott B
thanks
Scott B
My Feedback: (60)
ORIGINAL: docgboy
Sean,
thanks
Scott B
Sean,
thanks
Scott B
I would use a different mount for the jetcat, or install it so it is lower, and just jig it up to be inline. Actually the more I think about it, I would use pipe clamps and maybe BV's engine mount on the front, and then the nozzle clamp on the back. Yes, I only used the nozzle clamp to mount the nozzle to the engine, and to the former. I set the placement so that in no condition could the nozzle come lower than the exhaust cone (It would hit it only). This way I know I'm safe from deflecting hot gas inside the airplane.
My Feedback: (51)
Which other airplanes besides the rookie are good for a 2 axis thrust vectoring system ?
i recently got back from Gemany after watching ralf Losemann and his partner Enrico with their scratch built XJ10 with P160 SE - it was UN BELIEVEABLE !! he was doing full blown 3D with it, flips, harriers, torque rolls !!!
ORIGINAL: i3dm
My Feedback: (51)
This is very nice, but not quite what i had hoped to see.
After seeing Ralf's plane do harriers, torquerolls and mainly FLIPS and flat spins with changing direction - my heart is set on building a 3D jet as well, and im really kicking my head about which jet to get.
Ralf's plane has a P160 SE turbine (kero start) - any idea which engine is in that rookie or who's the pilot \ owner ?
My Feedback: (51)
Sean, would you rate your rookie as completely 3D capable for the manuvers i mentioned?
What kind of angle can you get on the nozzle ?
there's also this unit BTW :
Go to www.adjets.com - turbines - jetcat - close to the bottom of the page there's what appers to be the unit on this Mig 29 ?
My Feedback: (60)
ORIGINAL: i3dm
Dude, I think you should just get one and see for yourself. I don't think any of our jets are "3d" capable. The airplane will do some wicked stuff, but you're never gonna torque roll a jet. Nobody but Eddie Weeks would be able to engineer it to happen. You are welcome to prove me wrong.
As for angle of the unit, I don't know, never measure it. But my Rookie will spin on its ass continually all the way to ground and never move left or right.
My Feedback: (51)
I do not know Eddie Weeks but did you see Ralf Losemann's demo from Joe Nall 07 ? there was a video on the FG site.
BTW - which other planes besides the Rookie have the turbine mounted in the back to make them appropriate for Vector Thrust ?
and one last thing Sean, which turbine did you use in yours ? i think a P160SE would be needed to haul the Rookie really good !
My Feedback: (60)
I've flown Rookie II's on Rhinos, Merlins, Eagle's, Titan's, P-120's, P-70's.
Obviously the most vertical was the Rhino/ Merlin. But overall, the best engine is the Eagle.
P70 got the job done just fine for flying around and saying "Ooooohhh, I'm flying a Jet".
