TRITON CHARGER QUESTION
I just brought a trition charger with a eqinox balancer. I know this is primarily a field charger, but my LHS said that if I brought AC POWER cord that I could use it at home to charge my batteries. Heres my problemi-where the heck am I supposed to plug the AC/DC power cord at. Were they lying to me????
OH,
RE: TRITON CHARGER QUESTION
Yep! They lied to you, or made a very uninformed statement. The Triton chargers require a 12v DC power source. You can modify a PC power supply or find a decent regulated power supply. I found a Cosel K150AU-12 13amp power supply on Ebay for $23 a few years ago. I run two Tritons and a PolyCharge4 off of it.
Make sure you get a power supply that can push the number of amps you need to charge your batteries. Normally, AC Adapters that plug in the wall don't have enough. I'm using an MPI MX-8210 (http://www.maxxprod.com/mpi/mpi-9.html) - 9amp continuous. I think I paid about $50.00 at LHS. You'll need to either buy a power cord or chop one off an old lamp or something.
Remember, LiPo's can burn your house down. Change them safely.
Sean
Sean
I do have a power supply/power cord, I brought it from them when I got the Triton. It cost 49.95. I just dont see where to plug it into the triton so I can plug it into the wall outlet
OH
ORIGINAL: BUBBA633
I have used a Triton for years. It is a great charger because it tells me how many MAh have been added. Great for identifying problematic batteries.
My 12V power supply was purchased from Fry's Electronics (www.outpost.com) for $29.95.
