Has anyone converted a Sig Rascal 40 from Glow to Electric?
PA
Has anyone converted a Sig Rascal 40 from Glow to Electric ?
Here it is:
http://www2.towerhobbies.com/cgi-bin...1p?&I=SIGA6185
I might do the convertion but I dont know if the plane is heavy for EP??
Mine is red, about a 72" wingspan. Has a OS46fx engine in it!
I am tired of messing with engines.
Pls share ideas what kinda gear I need...thks!
--747
Here it is:
--747
BC, CANADA
RE: Has anyone converted a Sig Rascal 40 from Glow to Electric?
I have thought about this myself. I have a Lil' Rascal with a Astro 010 14 turn motor. I use a TP1320 3s1p pack. I would like to use A123 packs with Sig Rascal 40.
Check out http://www.rcuniverse.com/forum/m_6420046/tm.htm
also http://www.hobby-lobby.com/g2e-sigrascal40.htm
PA
Hi
Yes I saw the hobby lobby coversion too for rascal40...so do you have 2 rascals , one lil one 40 size?
I am sick of glow engine tuning, mess etc...
May be we can do this parallel!!
I love this gorgeous plane which flies great !!
--747
--747
BC, CANADA
I only have the Lil' Rascal.
ORIGINAL: 747
Hi
--747
Hi
--747
MI
Hi,
Novi MI here. I was given a wrecked Rascal 40,4 major subgroups. Anyway, repaired it
and put a Phasor 30 with a 3SP 3200 pack, a 60 amp ESC(overkill) and an 11X7 prop.
Balanced it right on the CG, set factory throws, and it flies great. Not a pylon racer, but
will do whatever you want. Came in at 5#, ready to go. Mix a little rudder with you ailerons
for nice smooth turns. I will be flying this plane in winter with skis, too. Hope this helps.
MD
I used one of the Hobby-Lobby short combo kits on one of my planes. It has great power and nice flight times. I recomend them to anyone wanting to go electric.
-Andrew
-Andrew
