SPE 40cc Problems
SPE 40cc Problems
Guys
Anyone had experience with the following with this engine:
Turning over by hand a notchy feeling as the piston comes to TDC,
Looking through the spark plug hole and it appears that the piston is hitting the combustion chamber,
Some scoring on the piston on either side of the exhaust port, and
the engine is brand new!
Thanks in advance
Peter
Thanks in advance
Peter
RE: SPE 40cc Problems
ORIGINAL: Ozmodeller
Guys
Thanks in advance
Peter
Guys
Thanks in advance
Peter
Guys
Thanks in advance
Peter
Guys
Thanks in advance
Peter
Looking through the spark plug hole and it appears that the piston is hitting the combustion chamber ?????? are you sure
send it back
WA
I have read about this in a previous posting..
It was covered under warentee... They must not start them
or EVEN TURN THEM OVER at the factory... Hard to believe..[]
Guys
Thanks in advance
Peter
Guys
Thanks in advance
Peter
