Tips on sealing a hinge line
IL
I need to know the best way to seal a hinge line using Ultracote white on the top side of the wing (in full view). I have seen some excellent sealing jobs and then some that looked like a 5 year old did it. So, I need to know where to start (i.e., wing trailing edge or aileron leading edge), wing trailing edge is squared, aileron leading edge is at a 45 degree taper.
Thanks for any help,
Jim
Jim
My Feedback: (25)
Deflect the control surface all the way. Lay a pice of ultracote which is bigger than the hinge area. Place a metal ruler along the hinge line. Iron on the aileron first and then the wing (altough it really does not matter - I just find it easier). Then take a straight, sigle edge razor blade and trim the covering at the top of the contrl surface and the wing.
IL
Seal Hinge line
Thanks for the replys!
I have to seal the top side because this ARF came with a slightly warped aileron - the gap at the wing tip is wider than the rest of the of the aileron and looks bad.
Clear tape
I've been using Scotch brand Crystal Clear tape. It's a little thicker than standard scotch tape so it's durable. It's nearly invisible when you rub it in, and It seems to be fuel proof, at least up to 15%. Best of all it's cheap.
IL
Sealing the hinge line
Fly4Fun2,
Thanks for your method of sealing the hinge line! I got brave and did it last night - it turned out to be very professional looking. It is actually hard to see unless you are looking for it. I'll post a picture when I finish putting some graphics on the underside of the wing.
Jim
Jim
RE: Sealing the hinge line
FYI:
This is 3M's "Blenderm" tape that holds very well even in the presence of fuel.
http://www2.towerhobbies.com/cgi-bin...?&I=LXJGT1&P=7
