What style controller do you use?
Old 10-23-2007, 10:05 AM
Kodiac400
Default What style controller do you use?
Hello. I'm new to RC and am wondering what style radio controller you use and what kind of work is required to change controllers?
Old 10-23-2007, 10:09 AM
guver
My Feedback: (325)
Default RE: What style controller do you use?
Nothing is required but a few adjustments if the freq is matched to the old one.
I buy mostly all cheaper RTR's on AM 27 or 75 mhz so I use a pistol grip 2PL from Futaba. It's not the best radio, but I usually run alone, 1 model at a time so it works out perfect for me as I can leave all the rx and crystals alone .
I have a 27 mhz with all 10 models memories filled and a 75 mHz with all 10 memories filled.
If you want to upgrade then the RX will need changing too.
Old 10-23-2007, 10:10 AM
nothinbetr2do
all my cars and trucks use a pistol style remote. as far as changing them, you would need a compatable remote and reciever w/ the right crystals
Old 10-23-2007, 10:19 AM
Kodiac400
What do you mean by reciever? The servo?
Old 10-23-2007, 10:22 AM
RCtruckRacer
RCtruckRacer's Avatar
The receiver is the unit that the servos plug into on the car. You need a receiver that is compatible with whatever transmitter you want to use. Usually, when you buy a transmitter, it comes with a receiver - but not always.
Old 10-23-2007, 10:32 AM
performancehobbies
spektrum,,,no interferance,,,and all you do is change the receiver --little box in the car with wires comingout ...
and even if you break your controller HORIZON will replace it for free,,guaranteed
Old 10-23-2007, 10:35 AM
GYNAIKAS
GYNAIKAS's Avatar
I use stick type. Even when I raced my RRR I used stick type...I find it easier to corner precicely and I handle better the throtle "feedback" .
Old 10-23-2007, 10:44 AM
nothinbetr2do
ORIGINAL: Kodiac400
a servo is the mechanical device that makes your wheels turn when you turn the steering on the remote, the same with the throttle, or ingages reverse if you have that. all the servos plug into a reciever, that's what tells the servos what to do,from imput from remote
Old 10-23-2007, 10:51 AM
performancehobbies
ORIGINAL: GYNAIKAS
when i went to see the worlds in france --i noticed alot of racers prefer sticks,,,,have you used pistol style?
how do you feel about the pistol style,,,?
it seems wierd but i remember having a few tyco buggies that had sticks and they were fun ...
i also seen alot of guys using rubber tires instead of foam ,,,
huh stick controller --i have a few here in the shop ?you think i should try it --i would standout thats for sure,,
what stick is the leader for rc cars ,,,or would most work ,,,i have a few hitech fm ones ...
Old 10-23-2007, 11:06 AM
DaveG55
DaveG55's Avatar
Most people in the States use a pistol grip controler for land based vehicles. And use stick type controlers for planes/helis. A pistol grip with the steering wheel seems more intuitive than a stick for controling direction. Also, since land vehicles usually only need 2 or 3 channels the complexity of stick controlers is not needed.
I understand that stick controlers are more popular in Europe.
Old 10-23-2007, 11:37 AM
GYNAIKAS
GYNAIKAS's Avatar
ORIGINAL: performancehobbies
ORIGINAL: GYNAIKAS
I've tried pistol style...it's not bad and I find it easy too but for me it can't compete the stick when you race on track. If you're mostly used to pistol type, at the beginning you'll find it a bit hard to get used to it, but once you do then you'll see it's more precice and you can work better the throtle "feedback" moves. Just get a radio with short sticks so that your moves are faster. Well rubber tyres last longer...but nothing compares to foam's grip. I often used rubber semi slicks but only at wet or rainy racing conditions. One of the best sticks I've tried or owned for rc cars use are:
SANWA Super Exzess ( http://www.dsaw-hobbies.com/articlea...yle1lang0.html )
SANWA Gemini II ( http://www.dsaw-hobbies.com/articlea...yle1lang0.html )
(They are both 3-channel digital FM radios at 40Mhz)
I have the Gemini II. That's the radio I use for all my cars (each car has his own receiver and servos...the Gemini II stock servos are on my 18ss cause I used racing servos on the RRR and EVOLVA that I sold with them).
I also have a Hitec ranger II AM but that's an old one that I have just for backup or other applications.
Old 10-23-2007, 12:20 PM
performancehobbies
i tryed it just about 10 minutes ago ---lol i have to admit it is sort of fun and makes for a new experiance,,
i used the ranger 3 fm ,,,seemed perty precise,,,actually it felt a little more precise,,,LOL,,,im going to race it this weekend,,
it was weird at first ,,throttling up ,,i had to get used to the brake,,but when in the straights it was like FULL force forward --felt cool
thanks...i like it
Old 10-23-2007, 12:42 PM
GYNAIKAS
GYNAIKAS's Avatar
Good luck budy! Just be careful on track! Get used to it first!
Old 10-23-2007, 04:04 PM
evil
evil's Avatar
I use a stick controller as i also fly heli,s i am comfortable with sticks. I use a KO Propo advantage R for my cars and a JR PCM9 for my Heli,s[8D]
Old 10-23-2007, 04:37 PM
GYNAIKAS
GYNAIKAS's Avatar
"Stick-users" club gets bigger!!!
Old 10-23-2007, 06:30 PM
annie_himself
annie_himself's Avatar
I use a pistol. I doubt I will ever go to sticks because I've always hated them. And it seems like you have to stretch your thumb to go full throttle or your thumb may even get tired during long mains.
Old 10-23-2007, 06:31 PM
sheograth
Moderator
sheograth's Avatar
Pistol style for my cars and trucks, and a dual stick for the one plane I fly.
Old 10-24-2007, 06:02 AM
GYNAIKAS
GYNAIKAS's Avatar
ORIGINAL: annie_himself
LOL...thumbs are ok...and handling more precise...I'm not as good at pistol as I am at stick but It doesn't mean that I hate them It's up to someone's style! Some say that stick is harder but faster (Collari for example...).
Old 10-24-2007, 06:22 AM
annie_himself
ORIGINAL: GYNAIKAS
It may be better, but I've gotten used to pistol now.
Old 10-24-2007, 07:20 AM
GYNAIKAS
GYNAIKAS's Avatar
I think you should follow what you've gotten used to...once you learn one type well enough there's no reason to jump into another. Keep the pistol style by all means!
