drill start
drill start
on the back plate 4 the drill start there is this little circle thing(where u put the stick in 2 start it) keeps falling out does and one no how i can get it 2 stay in al ready had 2 buy like three of them thanks any thing will help
RE: drill start
What vehicle is this in? Usually, the spin start has a plastic cover to keep the hex or cup in the spin start assembly. It may be that you need a new one of those, but without knowing what you have its hard to say.
RE: drill start
i have a himoto python and i just bought the back just put it of in the morning and i started it up and it was all ready off....u no the t bone looking thing that starts it well the thing that goes into that keeps falling out
RE: drill start
Looks to me like the washer/sleeve that keeps the drive cup in place is no longer connected to the plastic cover. I'm guessing that its just pressed in there, which is not the best design.
I'm guessing you can't buy just a new plastic cover and press in the old sleeve. You probably have to buy the whole spin start system.
You could try to use some sort of adhesive to reconnect the sleeve to the cover, but I doubt there would be a way to make that last very long. Honestly, your best bet is to get a different one:
That one should work. The cross reference for the TigerDrive can be found [link=http://www.sullivanproducts.com/TigerDriveXrefmainframe.htm]here[/link]
The part # for the Vertex VX-18 is S702
RE: drill start
hey thanks hommie really appreciate it ....i am gonna try 2 glue it since i just bought it 2 day and it allready broke but if it doesent work ill get that one i let u no how it goes thanks
Moderator
RE: drill start
Ive had that problem before, I too used some simple glue and it held pretty well. That said, I have the tiger drive on some of my cars and they dont fall out as easily.
RE: drill start
fell out again with the glue o well i am gonna get the tiger drive its pretty cheap and i am gonna get the 90 degree angel one it will b 10000 times easier
