A better linkage than the plastic
I think I need to replace the links on my servos and control horns on my plane.
I was checking the servo connection, and I noticed when the servo moved through full range, the piece of fuel line around the link was hitting the servo control arm.
I currently run the simple nylon quick links:
http://www3.towerhobbies.com/cgi-bin...?&I=LXE111&P=7
I'm currently running 2-56 control rods...
What's a better linkages???
Lyndon
Lyndon
My Feedback: (21)
RE: A better linkage than the plastic
http://www3.towerhobbies.com/cgi-bin...?&I=LXAZC3&P=M
....with this type, you don't use the pieces of fuel line.
OK...
I'm willing to buy what it takes...
But I have a question. My plane has the flexible pushrods, so the clips thread onto a length of metal, the other end of the threads goes into the inner pushrod, and extends in far enough to get inside the outer pushrod...
So, how do I convert to these??? Without doing anything drastic please....
TIA
Lyndon
TIA
Lyndon
Ok fellows, I suggest using the Sullivan LXFV17 metal clevises from Tower Hobbies, and do away with the fuel line, or plastic locks. If you add a lockwasher and nut on the threaded shaft, you can mechanically lock the clevis from moving on the threads. I have been taught to always use metal on plastic, or plastic on metal for any flight control system.
Rich S.
Rich S.
