Film Glue
Film Glue
hey guys on my farthers trainer where the exhaust oils hit the elevators the film is lifting,and im just wondering what the best methods are to fix this, is there a glue or something i can do to fix this, its driving me mad
RE: Film Glue
Id clean it up really well with rubbing alchohol, then seal it up with clear nail polish. get a bit under the flap and it will stick down, then seal over the seam and itll stay down
RE: Film Glue
What I have done on occasions is to clean the area thoroughly then aplpy some clear Monokote to cover the area that is lifting.
Use the same trick with trim to stop it lifting, expecially pointy bits which tend to be first to lift.
Terry
Terry
RE: Film Glue
don't know if you can get it in oz but there is a product here in the u.k. called prymol which is an etch primer made for that type of problem.
ON, CANADA
RE: Film Glue
Go to the hobby shop and get a can of Balsrite, that;s what it's made for. It's the same glue that's on the back of the covering film. Clean with alcohol. Paint the balsarite on the fuse or whatever. let it dry. lay on your monocoat that won't stick and iron it back down. works great.
My Feedback: (133)
RE: Film Glue
If it's an ARF with sticky-backed covering, clean it and either glue it down with thin CA or use clear packing tape (I keep a roll in my box for field repairs).
