honeykbee2 tail problem
my HBK2 tail spins counterclockwise when powering up.
all the trim tabs centered, servos at 90 degrees after the gyro initial.
I have flown the flight sim and this thing doesnt act nothing like it
the gyro gain is set all the way to the + side, rev mode and is factory stock, when i power it on when i slowly move the tail the gyro moves but seems after the fact. will try to video this maybe someone can help
thanks
thanks
SC
RE: honeykbee2 tail problem
First belt-tail heli? This is just one of the things you have to set up before flying. To set up the tail with a boom mounted servo:
Set rudder trim to center
Turn gyro gain to a bit less than half
Lift off
If it yaws CCW (nose left), loosen the mount screws, move the servo towards the heli body about 1-2 mm, tighten screws and try again
If it yaws CW (nose right), loosen the mount screws, move the servo towards the tail fin about 1-2 mm, tighten screws and try again
Repeat until the tail stays relatively straight on hover
Turn up the gain on the gyro until the tail twitches quickly left and right
Back off the gyro gain until there's no twitch
Even with a perfectly set up tail, it will yaw a bit CCW upon liftoff due to the motor torque. It will also slide to the left upon liftoff due to the force created by the tail rotors. All single-rotor helis do this, from Honey Bee FPs to Raptor 90s. Correcting this becomes second nature and the heli will settle into a straight hover in about two seconds.
Lift off
thanks for the reply
gonna have a close look at this today. i have watched a lot of youtube videos and my copter spins even say at 60% throttle. but i will definately give it a go today.
SC
Yeah, give it a go. It sounds like your servo is way off of where it should be. Follow the directions - a tiny movement forward or back makes a big difference. It may sound tedious, but, it is.
Be careful not to crash in one o' them Loo-z'yanner by-yoos.
ORIGINAL: dwightturner36
__________________________________________________ ___________________________________
Of all the things I ever lost....................................... I miss my mind the most!
