reverse on revo 3.3: Necessary?
Old 11-10-2007, 03:32 PM
ekimusman2
Default reverse on revo 3.3: Necessary?
Hey, guys. I'm just curious as to whether or not the reverse on my revo is worth keeping as i hardly ever use the function. can i just tear the reverse stuff out and make the car lighter and have it just be a no reverse like my 4-tec
thanks
i'm new to this
be kind haha
-Danny
Old 11-10-2007, 03:41 PM
skaterngolfer
Default RE: reverse on revo 3.3: Necessary?
yes you can just take out the opti drive and the servo for changing gears..... just make sure the rod that connects the shifting servo to th tranny cant get pulled in and out otherwise it can shift into reverse..... i had that happen to me and couldnt figure that out for a while! haha
Old 11-10-2007, 03:49 PM
Gustaf4096
Gustaf4096's Avatar
I really dont see the point in this "opti drive" when it only dictates if you can shift into reverse or not. Iam getting rid of mine, there is a "forward only conversion kit" that you can buy from traxxas.
"Forward Only Conversion Kit
The forward only conversion kit makes Revo legal for racing where reverse is not allowed. It reduces the internal rotating mass in the transmission for quicker acceleration and provides a small, additional weight reduction by eliminating the OptiDrive module, and the micro servo and linkage. When the transmission is fitted with the forward only conversion kit, the weight of the transmission is reduced by either 61 grams (when using the aluminum output shaft) or 48 grams (when using the optional steel output shaft).
Part #5394X Forward only conversion kit (eliminates reverse)
Suggested retail price $12.50"
Old 11-10-2007, 04:02 PM
ekimusman2
wow sweet...i'm buying that conversion kit tonight.
thanks.
also, is there a site with picture diagrams of how to do this stuff on my own (i want to learn without screwing my car up the first few times haha)
-Danny
Old 11-10-2007, 04:10 PM
Gustaf4096
Gustaf4096's Avatar
ORIGINAL: ekimusman2
thanks.
-Danny
Its quite easy.
1. Umount the linkages and wires connected to the gearbox.
2. Turn the truck upside down, release the 4 screws holding the skid-plate bolted onto the gearbox.
3. Use a small insex screwdriver to release the screw that is in the axle front and rear of the gearbox. ( you might need to turn the axle for the little screwhole to appear. But its there i promise you).
4. You should now be able to carefully take the gearbox out of the truck.
5. There are about 8-10 bolts facing the front direction of the truck on the gearbox that needs to be relased.
6. Split the gearbox in half..
Hey wait a minute, I think instructions are included
Old 11-10-2007, 04:24 PM
ekimusman2
AWWEEEEESOME
thanks!!!
Old 11-10-2007, 04:33 PM
dmx434343
here is a helpful link if your slow like me
http://www.misbehavin-rc.com/pit-lan...conversion.asp
Old 11-10-2007, 05:23 PM
ekimusman2
wow. you can't get much more explanation that that hahaha
thanks again
Old 11-10-2007, 08:28 PM
BigDen2.5R
BigDen2.5R's Avatar
The Optidrive also acts as a failsafe, so if you remove it do yourself a favor and get an after market failsafe, it will keep your truck from running away if you lose radio signal or if the truck batteries get too low. imo optidrive is junk, I smashed mine in my bench vice. lol
Old 11-10-2007, 09:04 PM
madmax22
madmax22's Avatar
yea im going to take it out of my maxx.....
Old 11-10-2007, 09:11 PM
Redrawker
ORIGINAL: BigDen2.5R
Dude, you shouldn't have smashed it! My lhs bought mine from me used for $15. That's easy money.
Old 11-11-2007, 03:44 AM
RCCanuck
don't buy a failsafe they are a waste of cash.....install a strong throttle return spring or rig your carb with rubber bands to return it to closed if you lose signal...at least half the guys on here that have run a failsafe post a thread on here about how it ran away on them even with a failsafe.......shoulda had a TRS
Old 11-11-2007, 05:10 AM
ttoks
ttoks's Avatar
i've had bad experiences of interference resulting in WOT runs over the huge ass burms at the BMX track, best best is both a failsafe and a throttle return spring.
Old 11-11-2007, 08:27 AM
TheKennyKiller
Banned
i got rid of my optidrive but i miss the pretty blue light
Old 11-11-2007, 09:00 AM
Redrawker
ORIGINAL: Daveorevo
Yeah, when I was driving on a dark night, the Opti-Drive would light up and make my body glow a cool blue color.
Old 11-11-2007, 09:59 AM
DaveG55
DaveG55's Avatar
ORIGINAL: RCCanuck
A TRS won't do a single thing if the RX thinks it's getting a signal (interference) and making the throttle servo go WOT. That's what a failsafe is for.
The only circumstances where a TRS is a help are where the throttle linkage pops off the carb and when the battery becomes dislodged/disconnected.
If people are having runaways with a failsafe installed then the likely cause is an improperly set-up failsafe.
Failsafes are not a waste, I've used them for years and they've saved more than one vehicle for me.
As ttoks said the best thing to do is use both a failsafe and a TRS.
