reciever problems
MI
reciever problems
hi i have a problem with my reciever every time i either go left or right with my transmitter the horizontal stabilizer also goes up and down. i am going exactly across and it also happens when i go up and down the alerions are moving also. do you think i can fix this or should i just send back the reciever
thanks
thanks
My Feedback: (9)
RE: reciever problems
The problem is more likely in your transmitter. Sounds like you've got a flaperon set-up and the servos are plugged into the wrong ports or else they are reversed.
What bran of TX do ou have?
Walt
Walt
