vx.16 cant run
vx.16 cant run
I have and exceed rc 1/10 scale buggy. I cant get it to run, if I put gas in the carburetor it would run long enough to burn the gas out, then it will cut off. I checked the gas lines and they are all fine. I'm new at this and I don't know what I'm doing please help me.
AZ
RE: vx.16 cant run
tunning or gas is not getting into the engine.
take out the gas line that connects to teh carb and close up the exhaust hole and pull the starter if gas comes out of the line then it might be a tunning problem, if gas wont come out then either clean or replace your lines. also check the plug
