Radio batteries
Radio batteries
i recently bought a radio but the cells where kinda mismatched in mah. All cells should be the same mah right? dose brand matter also or just the mah?
Nick
Nick
RE: Radio batteries
ORIGINAL: BuzzBomber
I would only use the same brand, type, and capacity of cells in any electronic device.
RE: Radio batteries
ORIGINAL: nick2618
nihm aa recharagables
In that case, yeah, definitely pick up a set that are all the same brand and mah rating. Otherwise, the cells will go further and further out of balance every cycle because they will likely drain at slightly different rates due to slightly different internal resistance.
The rechargeables from walmart are a good idea.
For the radio I use in my MGT, I have energizer 2300mah nimhs, they've done good by me. But for all my other RTR radios, I use(believe it or not) Sunbeam Heavy Duty Alkaline AAs from the local Dollar Tree store. I get 'em at $1 for a pack of 8 cells. They're so cheap I keep at least one spare set in my tool bag, and they last about a month of bashing for an hour or two every weekend. I normally wouldn't advocate alkalines, but these are SO cheap and radios use not much power, it would take me a year and a half to pay the equivalent of nimhs.
