pull pull rudder
RE: pull pull rudder
Yes, I do it all the time. I've used nylon coated stainless steel fishing leader (my favorite), plain old nylon leader, spiderwire etc. all successfully. Most times I use something over 15 pound test but you could most likely get by with less. As long as it is stronger than the servo can pull, it should be fine.
My Feedback: (18)
I like the nylon coated leader wire. You can generally buy it in a kit with crimpers and everything else you need for the pull pull. I just use threaded couplers on one end and drill a hole through them and then use the leader wire set.
