BVM wing 'Skidz' - position on a Bobcat?
1 Post
Guys, as I build but do not fly jets [] I wanted to ask where is the best place to position the wing tip 'skidz' on a Bobcat Comp.
I know they need to be at the tip, but is there a best place based on the wing construction and prone areas of possible landing impact?
Cheers for the help.
marcs
marcs
My Feedback: (26)
RE: BVM wing 'Skidz' - position on a Bobcat?
Since most wing tip skids are positioned wrong,and you don't find out untill your wing grinds down,the best way I found is this.Have the model assembled and on the gear.Collapse one of the mains and note where the wing touchs.That is the pace to install the skid.Same procedure for a nose skid also.
My Feedback: (27)
For planes that have a tendency to scrape a wingtip on rollout (i.e. narrow mains), I'd leave all the gear down. Sit the jet on the floor and tip it up by one wingtip. Make sure the nosewheel and one main are touching the floor. Mark the spot where the opposing wingtip touches the ground, and then use whatever method of "scrape prevention" you prefer.
For planes that don't have reliable gear, then Jet Lag's method would be best.
If you have both problems, use the classifieds...
edit - I doubt you're going to have gear issues with a Bobcat, and the gear is spaced pretty wide too, so if you're scraping wingtips on rollout you're landing a bit too fast.
ORIGINAL: RBardin
My Feedback: (27)
Hmm...you have point I forgot about, Bob. My KingCat does that too, if (when) I bounce it. I need your method on my Fury - or some tailwheels - or someday I'll learn how to land it better...!!
I found some softer springs for the KC mains, and it made a big difference. Try changing springs or use those struts from Todd.
Do you use crow on your BC?
RBardin, I bounced the Bcat 2 or 3 times in the first 30 or 40 flights and scraped the wingtips. Also took out flex plates and rudder servos. The plane was setup as per BVM, including crow. I found that moving the cg back about half an inch helped a bunch - seemed like I was a bit more comfortable at lower speeds in the landing pattern, and I think having less weight on the nose gear helped reduce the tendency to pitch the nose back up on contact with the pavement. FWIW. Fortunately, I haven't bounced it in a while, but it is probable that I'll do it again.
Edit: Since I managed to hijack the thread (sorry) and get on the subject of landing technique, I highly recommend that turbine newbies read a couple of articles on landing technique that were published in the JPO newsletter in Summer 06. One of those articles is on the JPO website. Helped me a bunch.
1 Post
My concern is having something to glue the 'skidz' to, as the wings are composite I do not know if there is any material in the tip area which will allow me to glue them in well - any ideas from the BVM clan?
marc
Marc, I haven't seen a cross section of the tip, but there is a pretty solid core of some type under the glass skin at the tips of my BobCat wings. You should be able to glue the skidz just about anywhere you choose. As for the best location, I second the previous recommendation that you tip a wing down and slightly forward with the nose gear and one main on the ground. Wherever the wing tip touches the ground is where the skidz should go. As I recall, that is about a third of the way back from the leading edge at the tip. Just my recollection FWIW.
