Air Tank Location
My Feedback: (48)
Air Tank Location
I'm building a FEJ F-16 and would like to get the air tanks out of the nose so that I can mount a base loaded antenna there. The only other location in the plane where there is room for the air tanks is on each side of the tailpipe. They would have about 2 inches clearance from the outer pipe and of course I would shield them with some ceramic blanket and aluminum tape.
I have seen a few installation photos of air tanks in similar locations. My question is whether or not they would get hot enough to noticeably increase air pressure or present any functional concerns? I'd appreciate hearing from anyone who has mounted their air tanks in a similar location.
The alternative is to go with much smaller tanks and I'd rather not do that.
Joe
Joe
NJ
RE: Air Tank Location
I have my air tanks mounted in my Rafale along the side of the pipe and I have never had a temp problem. you should have enough air flow in that area to negate any heat from the pipe that may cause any problems. I also do not use any heat shielding for the tanks.
Alan
Alan
My Feedback: (12)
ORIGINAL: joeflyer
Joe
Joe
Thats exactly where I have mine in my Tams F-16 adn they are fine. I dont even have any ceramic blanket on them. I double walled pipe should be fine for keeping the heat off them.
My Feedback: (48)
How big an antenna are you putting in? I have two air tanks and a Deans antenna in the nose of mine......
Joe
I have the air tanks in my Super bandit mounted aft, below the tailpipe, since I built it in March of 2003, and have had no issues in that location.
They are mounted in the lower corners of the fuselage, a couple of inches below the pipe.
A double walled pipe and a bypass tube keeps the temperature below a dangerous level. I have no heat shielding around the tanks, but I would not hesitate adding it if necessary.
See my thread entitled "Fabricating a Thermal Blanket" for a tutorial if necessary.
Harley Condra
BVM REP
JetCat REP
Harley Condra
BVM REP
JetCat REP
