Go Back  RCU Forums > RC Helicopters > Electric RC Helis > E-Flite Helicopters
Blade 400 - unplugging the motor
E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
Old 01-13-2008, 10:52 PM
joediamond
Default Blade 400 - unplugging the motor
Has anybody figured out an easy way to unplug/plug the motor leads? The leads from the motor seem awfully short and difficult to get to. Using pliers or tweezers to grip the plugs does a job on the insulation.
C McCarthy
Old 01-14-2008, 12:06 AM
Torquestar
Default RE: Blade 400 - unplugging the motor
EDIT: I mis-read what you wrote... thought you were talking about battery leads.
I wish the motor leads were easier to undo as well. I need help from someone else to hold them still while I plug them back in!
Old 01-14-2008, 12:21 AM
Wolfpackin
Wolfpackin's Avatar
Agreed that it is a poor design.
They should have, at least, made them longer.
I'm leaving them alone until I need a new motor.
Until then I'm using throttle hold for all testing and pitch measurements.
Old 01-14-2008, 01:04 AM
damonlee
Yeah, I haven't found a major reason to disconnect the motor...very difficult to get to the leads.
I myself was going to use needle-nose pliers to try, but didn't want to crimp the connectors.
The only other thing I can think of is to maybe dremel an access point in the frame...
seems like alot to have to go through..
