What Motor mount for for OS 160?
My Feedback: (12)
Use the Great Planes adjustable mount, the black one which slides horizontally to accomodate engines of different width.
Only thing is that mount will not fit in the widest slid opening so you will have to use it mounted wider than that. But it works fine.
Bolt the mount to something before drilling the engine holes in the mount so that the holes come out in the correct place and the mount is kept flat to the firewall when it is bolted to the engine.
