CP PRO TO A CP+
My Feedback: (26)
CP PRO TO A CP+
Has anyone changed the bell-hiller mixer on a cp pro to a standard cp+.If so what parts does it take? A upgrade mixer kit to a pro is available,but I can't find the stock mixer listed as a unit.
NE
RE: CP PRO TO A CP+
I have done that before. It only needs the CP+ blade grips which are about $8. It is a great way to fly the CP pro. I advanced a lot faster on my flying skills doing that then trying to learn with the bell hiller. Then when you are ready to upgrade put the bell hiller system back on.
NE
RE: CP PRO TO A CP+
The grips don't come with bearings so you will need to pop them out of the CP PRO ones. Then you will need to adjust the grip linkages to make the track correctly.
