OFFICIAL FORUM HOST - yadac123
RE: OFFICIAL FORUM HOST - yadac123
Hello Andy,
I bought an Exceed 1/10 Nitro Extreme Forza buggy and i love it. No problems with shipping when I ordered from Nitrorcx.com. Only problem was I didn't get an antenna tube when I got my car (a bendy straw worked). Other than that i love it.
Don
Don
Don,
I can help. Let me know your order number with nitrorcx and I'll send one to you.
ORIGINAL: ldgasp
Hello Andy,
Don
Hello Andy,
Don
Andy, got my antenna tube today. thanks so much. i know its like $1.00 piecew but, you sending me one proves you are here to help. Thanks alot.
Hello Andy,
I bought an Exceed 1/10 Nitro buggy (and an electric track). I ordered it from Nitrorcx.com. I have a problem with nearly since i bought it is that i can get the engine to run good. the carburettor will not get tuned whatever you do.
to get the car to perform little bit you have to unwind the needle valve all the way out.and still the car will not perform in a normal way. i have removed the carburettor clean it put it back nothing..new glow plug...still nothing. the car hesitates at high and low rmp. i know how to tune the engines...i have helicopters ..planes....other nitro cars but is the only one giving me such carburettors problems.
any suggestion.?
JASON
any suggestion.?
JASON
so you engine starts but it quickley dies? Make sure your idle scew leaves a 2mm gap at idle. Full idle show not open all the way and 3 quarter is be ok.
Andy
Andy
The engine runs on idle with no problem. the problem is once you want the car to accelerate. I have other engines one other cars plane helis and i can tune them with no problem. this engine does not want to be tuned what ever you do to it. i have done all settings all test...the pinch test for the low screw...i have done the test if its leaking air...etc...everything but with no change. also i have noticed that when the engine gets to running temp and when using it for some time.....the high needle adjustment screw it becomes loose and rotates on its own. HELP...its getting really annoying. It run perfectly only for a couple of days since i got it... after that.....
Thank you Andy.
But it want be easier just to sent the carburettor? Because i Live in Cyprus (small European island in the Mediterranean Sea) and will take some time for the engine to be sent back to the USA and then the new engine to be sent Back to Cyprus.
Please let me know what to do.
Sure. If you think that's the problem i'll do it. what's your order number?
Andy
Andy
ORIGINAL: cute_mr2
Thank you Andy.
Thank you Andy.
hey Andy
Thx for that. I have read other posts that more people are having problems with adjusting the carburetor.. and with the needle screw coming loose. i hope that the new one that you will sent does not have the same problem. cross our finger.
Another thing is the back left wheel bearing has come apart and i was wondering if you could sent a set of those bearings together with the carburetor and i will pay for those bearings. also i have seen that the have a steel exhaust for that engine but nitrorcx says that the item its out of stock..will it be possible to find one of those somewhere? if you can please let me know so i can get them sent all together
My order Number is: 244320
thank you for all the help
the alumin exhaust will be back instock soon. The high end needle has a rubber o-ring to obsorb the virbation and please make sure that o ring is still there. also if you can get me the part number for the part you needed
Andy
Andy
To whom it may concern:
I guess I am a new customer to this company and I am already a bit peeved with you.. I do know that I did not have to order but I did.. Your customer service people must answer the phone for two or three companies are not extremely well trained in the products they are taking credit cards for and to TOP IT ALL OFF !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! You do not HONOR the pricing you advertise on your website!!!!!!!!!!!
http://www.nitrorcx.com/contactingus.html
http://www.nitrorcx.com/aboutus.html
http://www.nitrorcx.com/clearancesales.html
and any other page on your web page lists the titan 1/8 scale truck at 249.95 but when you add it to your cart it comes up at the 269.00 price!!!!!! So at that point I decided to call in and I did had to wait till a little after three here on the east coast asked the person was the titan in fact on sale at 249.95 and yes was the response I received I said wonderful you want my cc # well not yet what website did you find this on?? Etc!! What the crap does it matter what website I found it on???? I called you looking to buy !! so after going through a process of seeing what website I bout it on and giving the csr the addy I was informed that 249.95 was the wrong price at that it would be 269.00 or whatever I agreed and bought the thing anyways… I really feel like I need a credit of 20 bucks or some extra tires wheels shocks or something I am gonna leave this in your hands and see what happens.. hope to hear from you soon.. oh yes I still would like the truth on this matter as well are these trucks exact to the hsp tornado or are they a knock off of a knock off??? One big reason I ask is the tornado is advertised on your site at $100.00 more that the titan?? The csr couldn’t answer that ??????????? either so with that said I am leaving this in your court and waiting to hear..
Sincerely,
Brannen Samuel
Sincerely,
Brannen Samuel
i have changed the needle o ring with a new one but nothing.
the part numbers that i need are: 1 ) 2043 (brake cam) the top of the cam broke. 2) 2079 (oil bearing) i think that this is the part number for the bearing for rear outer hub assembly for rear wheel. it does not show on the drawings in the manual the part number for that bearing.
I can not find the 2 part you requested. I'll send you a carburator plus 2 parts. parts number starts with 51c00-
Andy
Andy
ORIGINAL: cute_mr2
Andy
this are the correct part numbers
1) Brake Cam 51C00-02043
2) Ball Bearing 51C00-02138 (Is this is the part number for the bearing for rear outer hub assembly for rear wheel???)
ON, CANADA
Hi Andy!
I received my spare rims and tires today in the mail. Thanks for that. I'll let you know about the colours when I open the box. I need to know something else from you too. Can you check my new thread.
Aaron
Aaron
Your parts has been sent.
Andy
Andy
ORIGINAL: cute_mr2
Andy
Andy
Location: Bakersfield CA now watford UK, UNITED KINGDOM
Hi Andy I was on the nitrorcx website and seen the wild blue Exceed and wanted to know if I can buy the blue wheels that are on that truck here is a pic of the wheels I want thanks.
