C-ARF 2.6m Extra 300SX Components
MD
I am finalizing getting a quote for my C-ARF 2.6m Extra 300SX, and wanted to get on ordering stuff for the plane, and had some questions:
1. What is the spacing on the rudder horns? I want to use the SWB 1X Servo tray w/ bellcrank, and wanted to know which offset is correct?
2. What servo arms are you using on ail/elev? My guess is 1.25" elev, 1" ail, but I could see other setups
3. I'm doing the H9 Titanium Prolinks, so I need to know the pushrod lengths for elev/ail, what lengths are you guys seeing?
4. With a DA 100 up front, what are you using to shim and offset the engine the 30mm they are recommending? SWB has a 2.5 deg shim and available spacers.
5. Any problems with using the C-ARF 120mm CF spinners?
6. Any problems with the 35% titanium tailwheel? I like RC BlimpPro, but they say this is lighter than CF...
