Brakes have gone insane!!!!!!
Hi i have a jammin x1-crt and i my steering servo is messed up horribly. It doesn't matter how hard you push it to put the brakes on, and the brakes wont bite? I dont get it so please help? Do i need a new servo?
WA
RE: Brakes have gone insane!!!!!!
If you are able to, perhaps clean the brake pad or buff it with sandpaper or a dremel. This drastically imporves to grab or bite on the pads to the brake disk.
If it doesn't work, try out a higher torque servo. One with around 80-100 oz/in will do just fine.
Good luck!
Good luck!
Another suggestion may be tightening up the brakes. My revo wasnt stopping because I didnt have the brakes tight enough. On the throttle connector should be a circle thing with teeth and a spring in front of it. Turn the circle thing to depress the spring and see it that helps.
