HPI Monster Truck Forum Talk about HPI monster trucks here. The infamous Savage 21, SS, .25 or any other HPI MT. You can optionally discuss HPI in our general MT discussion forum if you prefer.
a new heart for the monster!!
Old 02-14-2008, 06:48 PM
ravenlunatic
Default a new heart for the monster!!
my Picco .28 P3 came in and i just finished mounting it in my savy i tried to starting for the first time and it seems much easier then the K4.6, no blisters. i bought a temp gun, after run oil and a new standard plug all for breaking it in this weekend. if you guys have any tips or suggestions for a good break in process please post and let me know. i broke in the k4.6 by the "tires of the ground" method last time and it had air leaks like no other. i want to do it right this time to bring out the true power of the picco with out moding it.
Old 02-14-2008, 07:01 PM
Parputt537
Default RE: a new heart for the monster!!
Seal it up before you run it and use the heat cycle method to break it in.
Old 02-14-2008, 07:05 PM
ravenlunatic
ORIGINAL: Parputt537
are picco's prone to have air leaks?
Old 02-14-2008, 09:42 PM
Vigilante212
Vigilante212's Avatar
all engines are prone to have air leaks
Old 02-15-2008, 10:17 AM
ravenlunatic
hmmm....ok! did it last night, didn't want to take any chances so i did some research and found this:
part1: http://www.youtube.com/watch?v=RM0BT...eature=related
part2: http://www.youtube.com/watch?v=EwDZf...eature=related
part3: http://www.youtube.com/watch?v=DdTUM...eature=related
this was really helpful so i figure i'd share the wealth to those that are new.
Old 02-16-2008, 04:29 PM
ravenlunatic
WOW!!!!! on the fourth tank the picco was already lifting the front wheels[X(] then on the next tank got a bit trigger happy and put my EXTENDED LCG savy on its top! this motor is crazy! i could barely lift the front wheels of my savy an inch with the k4.6 at 100% throt. with the picco i was running at 70% throt. looks like it's a good thing i left the wheely bar on i put in six tanks today, how many tanks should a break-in process take? i know at least four tanks, right?
Old 02-16-2008, 09:20 PM
-SomeGuy-
-SomeGuy-'s Avatar
If your impressed with what you see now wait till you get a little over a gallon through it, they open up nicely at that point. So far the break in and tuning has been a real breeze on all my picco engines. You made a good choice, enjoy!
Old 02-16-2008, 09:25 PM
twomanytoys
The Picco P3 is the mill to have for raw power. Its got sick torque.
Old 02-17-2008, 12:29 PM
ravenlunatic
i can clearly see that I may have to get another one for my LST2. BTW do you guys think six tanks is enough for a break in? it was a nice day in Iowa (20-25 degreesF) so i jumped on the opportunity.
Old 02-17-2008, 01:46 PM
supertib
supertib's Avatar
ORIGINAL: ravenlunatic
take it easy on th emotor for the first liter or so...then by half a gallon you can start working it a little harder........ full break in will take about 1.5 gallons....... the motor will still run well but it wont open up till all the metal pinch is gone....
Old 02-17-2008, 05:12 PM
ravenlunatic
really? i've only put about 1/4 gallon through it... when should i start to tune it? i have not messed with the needles yet and it's already haulin the savage better then the k4.6
Old 02-17-2008, 05:34 PM
mazdab2600
mazdab2600's Avatar
mine's running 20/47 gearing 2spd and byrons 20%.
i'm only at my 6th tank and still haven't touched the needles.
going the same route as my lrp 10 tanks before i start playing with the needles.
pic of the beast.
Old 02-17-2008, 07:18 PM
ravenlunatic
do you bring extra batteries? ten tanks is a long time. it took me three hours to do six. i had to change out my reciever bats and my transmiter bats on the sixth tank. now i'm waithing on the storm to pass to get another six or so tank through. is it bad to have a "break" in the break in process? i really didn't have a choice[:@]
Old 02-17-2008, 07:23 PM
Vigilante212
no raven its fine.
Old 02-17-2008, 07:24 PM
mazdab2600
mazdab2600's Avatar
nope you can take as long as you want for the break in.
just make sure to use some afterrun oil(aro) and set the piston a bottom dead center(bdc).
i haven't ran mine for acouple of weeks now.
bad weather/work/busy.
batteries-i've got 8 hump packs. 2 for each truck.
Old 02-17-2008, 08:22 PM
ravenlunatic
that's good to hear. thanks alot for your comments guys. now all i've got left to do is sit and wait on this wonderful weather i'm having in Iowa to pass
Old 02-17-2008, 08:23 PM
ravenlunatic
oops! pressed the button too many times
