What Does This Fuel Line Do?
WY
RE: What Does This Fuel Line Do?
Most factory intakes use a "worm hole" to bring the pulse to the carb. FPE makes a new intake to rotate the carb so its easier to use on a model. So its simpler to use an external pump line. No big deal. The Zenoah 45 and GT80 both use the same.
My Feedback: (98)
No, it has to do with the carb mounting block. Most of the conversion type engines have them. They usually rotate the carb so the throttle is easier to hookup by using a carb rotating block that blocks the internal pressure pulse channel. Any carb you put on this engine will need this.
My Feedback: (98)
ORIGINAL: Pat Roy
Sorry Terry, you got overruled Haven't you been doing conversions for about 20 years now?
