GAS RIGGER NEED HELP
HEY EVERY ONE NEED HELP I AM LOOKING AT BIULDING A GAS RIGGER
CAN ANY ONE HELP ME WITH PLANS OR ANY THING AS IN WEB SITES
WHAT IS FIRE FIGHTER GAS RIGGERS LIKE
PLZ HELP THANKS JAMES
RE: GAS RIGGER NEED HELP
Tom Morehouse did an EXCELLENT job designing the Fire fighter riggers !! They work really well and in the right hands can be a lethal tool against the competition.
** Riggers tho are by design the MOST SENSITIVE to the accuracy of the build. Squareness, accuracy of all angles & ride surfaces must be SPOT ON for them to run right at speed !
#1 issue that plaques them is a decent cowl that keeps water out of the carb during the launch & while running. even a small amount of water spray getting into the carb quickly ruins the engine.
Good luck in your quest
ORIGINAL: jimmy 1987
[link]http://firefighterboats.com/[/link]
have a chat with Aaron at Ozspec hobbies, he's in Melbourne & races them. I get him to mod my props for me, he's good to talk to to get ideas from.
http://www.ozspechobbies.com/
Hi Jimmy they look pretty easy to me ,havent built one yet but theres a gas rigger been built on the forum if you have a look.
[link]http://www.rcuniverse.com/forum/m_6720494/tm.htm[/link]
hey thanks for the help what are the fire fighter plans like any good are they hard to do
The build itself isn't difficult at all, but as Scott mentioned earlier, it is absolutely paramount that things be built straight and true, otherwise you will have a whole raft of problems on your hands when it comes time to run it.
As long as you're patient and accurate you will get a good result.
Riggers are addictive, I personally find them fun to build, turning a heap of sticks into something that goes as fast as they do give you great satisfaction, but set ups on them (or any rigger) can also be a point of great frustration.
Build one, you wont regret it
Johno
