NiCd batt. charging
NiCd batt. charging
my stepdad just bought a new charger so he could get a 5000mAh batt. i got his old NiCd charger and 1800 batt. what is the highest mAh batt. that a NiCd charger can charge?
RE: NaCD batt. charging
A NiCd (Nickel Cadmium) charger can charge any size battery you put on it. Some just take longer than others. The best charger to use is a intellapeak charger. These will do all the work for you.
Are you sure he has a Nicd battery and not a NiMh battery. Most NiCd batteries in general only go to about 3000 mah. The NiMh are the big ones.
the old one he had that he gave me is a NiCd and my lhs told me they would only charge 1800 batts. the new one he bought is a NiMh which he uses for his 5000 batt
RE: NiCd batt. charging
Nicads go up to 2400 size havent seen any bigger,dont try charging a nimh battery on a nicad charger tho bad ideal lol
i charge my 1900 and 2400 on a cheap nicad quick charger no problems tho the 2400 takes a bit longer than the 1900
I have 2 panasonics that are about 3 yrs old. I only use them in my roto starts not my electrics. granted now days I dont think you can find nicd that big anymore because of nimh. They are sub c too.
