HIT THE WATER TODAY WITH RIO
Old 03-30-2008, 06:27 PM
hummitlargescale
Default HIT THE WATER TODAY WITH RIO
DROVE THE RIO TODAY SET THE NEEDLES LIKE GRIM SAID DIED THE FIRST COUPLE OF TIMES THEN HELD IDLE UP AND THREW IT IN.DROVE ABOUT 5 MINUTES AND THIS IS ONLY MY THIRD TANK SO i WAS JUST DOING SLOW TO MED LAPS BUT IF I TRIED TOO OPEN IT UP THE RPMS DIDN'T RAISE UP GOOD SO BROUGHT IT IN AND ADJUSTED THE HIGH NEEDLE TO TRY TO FATTEN IT UP A LITTLE(WAS AFRAID I WAS TO LEAN AND i HAVE NO GOOD WAY TO CHECK THE ENGINE TEMP) SO I STATERTED IT AGAIN RAN TERRIBLE THEN DIED TRIED TO LEAN THE HIGH NEEDLE SETTING STILL RAN BAD WELL AFTER TOYING WITH BOTH NEEDLES I SET THE L TO 2 1/4 TURNS AND DON'T REMEBER WERE H NEEDLE WAS STARTED IT UP THREW IT IN AND IT RAN PRETTY GOOD BUT AT FIRST WHEN I WOULD DO BRIEF WIDE OPEN IT DIDN'T WANT TO CLIMB UP FAST BUT TOWARDS THE END OF MY RUN IT REALLY SEEMED TO GO BALLS OUT FOR A FEW MINUTES WHEN I WOULD ACCEL.THEN I RAN OUT OF GAS.ANY SUGGESTIONS ON THIS DO YOU GUYS THINK IT WAS RUNNING GOOD AT THE END BECAUSE OF LOW FUEL LEANING IT OUT?(I DON'T BECAUSE IT DROVE FOR A COUPLE OF MINUTES GOOD) OR COULD THE ENGINE JUST BE BRAEKING IN COMPLETELY NOW.I GAVE UP FOR THE DAY BECAUSE MY HAND IS BLEEDING FROM PULLING AND I THOUGHT I SAW TWO DUCKS LAUGHING AT ME EVER TIME I PUT THE CANOPY ON AND IT WOULD DIE OUT.THANK GOD FOR RECORY ELECTRIC BOAT FIXTURE IDEA I TOOK FROM YOU GUYS.I HAVE A LITTLE EXTRA OIL THEN RECOMMEND AS I THOUGHT THIS WOULD BE BETTER FOR BREAK IN I KNOW THIS WILL EFFECT IT A LITTLE.I AM MAINING TRYING TO FIGURE OUT WITHOUT GETTING IN THE WATER WITH THIS THING HOW DO YOU GUYS ADJUST YOU NEEDLES IT SUCKS SHUTING IT OFF TURN IT 1/8 RESTART DROP IN ETC ETC i WOULD LIKE TO LEAVE THE TOP OFF AND GET IN THE WATER AND JUST DO A COUPLE LAPS ADJUST IT RETRY UNTIL I GET IT OK.OVERALL THIS THINK DID MOVE OUT
Old 03-30-2008, 08:49 PM
Justaddwata
Justaddwata's Avatar
Default RE: HIT THE WATER TODAY WITH RIO
Old 03-30-2008, 09:13 PM
JCAustralia
Hard to read upper-case characters.......[8D]
Old 03-31-2008, 04:10 AM
martno1fan
martno1fan's Avatar
Sounds like shes running way to rich set the low to 1 3/4 out no need to stop the motor to tweak the needles idling for a few seconds wont hurt just dont do it for too long or things get hot very quick [X(].Also if you used Grims needle settings are you sure your getting enough movement on your throttle setup to open the throttle?,he should know where the needles should be so maybe try what he suggests and check for other things to make sure there isnt another reason for her not revving out?.My money is on the low needle been too far out though close it half a turn and see .
Mart
