What sealer for Quadra engines??
04-01-2008, 10:58 AM
NJ
What sealer should I be using to seal the crankcase?
Seems most anything I use ends up leaking a little
04-01-2008, 12:47 PM
RE: What sealer for Quadra engines??
Try Loctite Xtreme it's a high temperature adhesive that I've had great luck with on mufflers.
04-01-2008, 10:16 PM
locktite 515 flange sealer
This is the sealer used by many oem engines with split cases.
giant
