Go Back  RCU Forums > RC Helicopters > Electric RC Helis
Mini Titan Setup Questions
Old 04-02-2008, 11:22 AM
smarks
smarks's Avatar
Default Mini Titan Setup Questions
I have a few questions on the setup of my MT:
1. How tight should the tail belt be and what is a good way to know the proper tension?
2. How easy should the head spin by hand? I am wondering if the tail belt and motor gear lash are too tight because the head will stop fairly quickly after spinning it by hand. I did the paper strip test between the motor and main gear and the paper came out looking OK like an accordion with sharp edges. The paper was not mangled.
3. How tight should the main blades be in the grips?
4. When your gyro is properly setup, will you never need to use rudder trim? I am using a Hitec HG-5000 gyro FWIW.
Thanks!
Old 04-02-2008, 02:31 PM
BarracudaHockey
BarracudaHockey's Avatar
Default RE: Mini Titan Setup Questions
ORIGINAL: smarks
Loose as you can get it without it skipping a tooth when you hold the tail and try to turn the head with a moderate force. If you force it it will skip a tooth. Its kind of a feel thing. If you poke a screw driver into the opening at the rear of the frame and can easily push the belt and touch the other side of it it's too loose, if it feels like a banjo string its too tight.
Sounds good, see 1, if the belts too tight it wont go around too many times. Also these blades don't weigh much so they don't carry a lot of intertia.
Tight enough to hold the heli on its side and not flop around, loose enough to move when you give it a shake.
Thanks!
True
Old 04-03-2008, 12:58 AM
smarks
smarks's Avatar
Thanks for the advice Andy! I think I have the belt too tight which may be giving me my gyro problem. I also think I have the main blades too tight in the grips. I have to give it a good shake before the blades move.
Old 04-03-2008, 07:55 AM
BarracudaHockey
No problem.
If the blades are too tight you can get vibration when they try to lead and lag (pivot on the blade bolt) and vibration will cause gyros to act up and drift.
Old 04-07-2008, 10:58 PM
smarks
smarks's Avatar
Great info. Thanks again Andy
