Prop hub
Prop hub
Need a source for prop hubs for ZDZ 40. Not spinners, hubs. Prop shaft size is 5mm and it needs to fit inside of the prop mounting bolts, or be groved around the outer circumference to fit over them.
Can't stand that threaded hole in the middle of the prop on my GBY.
Could also use source for metal looking props.
Tried all the usual choices with out luck.
Thanks in advance.
Thanks in advance.
