rescue boat question
just want to get an idea of a rescue boat that i can use in case my gas cat stall out in the middle of the lake. I was thinking of using the aquacraft atlantic tug boat...anybody think this is a good idea? does the boat have enough power to push a 55in cat back to shore?
RE: rescue boat question
sure,if it is a small lake,and your up to the challenge of manuevering that critter in,....but this type of fun creates ALOT of "down time" spent on retrieval.....,you'd be better off getting a fast electric,like a villian,attach your shore pole to it,run it on out,do a u-turn,and bring it on in.....i find the benefits of attaching it to a shore pole is that if it runs out of range,you wont have TWO boats stuck out there.....[:@] be sure you have a cleat or hook attached to your boats to make snagging easier....
Banned
ORIGINAL: nguy0951
I use a 2 man inflatable boat, came with oars and an air pump for $60 delivered from Ebay. Have a string tied to a loop at the back of the "rescue boat", and I hook it to the boat dead in the water. I then pull it in as I row back to shore instead of picking it up and into my inflatable boat...think about it...sharp turn fins, sharp rudder....get the picture???
-Scott
-Scott
Banned
[quote]ORIGINAL: Dreamin Hemi
-Scott
[/quote
That's a good deal, where is the link?
[link=http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=110225643290]Ebay 2 man boat[/link]
Here was my listing. Search around a little, you'll find other current auctions.
Banned
Hey, hope that helps a little.
I've been thinking of an r/c rescue myself. I like the recovery barge plan, looks like a good idea. strap that to a Villan or something....any more pics of rescue ships out there?
ORIGINAL: martno1fan
heres one,not mine but i plan on building one.
It's actually a really good boat expecially for an inflatable. The material is way thicker than what you will find at walmart. But if cheap is what you want, you can find a 1 man inflatable for about $20 there, however you get what you've paid for. I returned about 3 of these last year. This Ebay boat has survived a dozen or so trips and I've only inflated it once (the first time out of the box). Holds air great!
Good luck!
-Scott
Good luck!
-Scott
Banned
ORIGINAL: nguy0951
hey thanks guys for the help!, i think i might just go with that inflatable boat on ebay, cheaper way to rescue my boat
Thats true and still by far the cheapest and safest way to rescue a boat is the old fishing rod with tennis ball attached,works great for as far as you can cast .For some that could be 100 yards for others 10 ,whatever you do dont ever swim for one its not worth the risk.
Mart
ps Dicko sorry to steal yer thunder ,ill also be stealing the idea thanks mate
Mart
My Feedback: (51)
In case you didn't get the ebay boat.Here's lots of inflatables and don't forget the life vests.
http://www.kodiakoutback.com/SearchResult.aspx?
http://www.kodiakoutback.com/Stearns-Life-Jackets.aspx
Yep, can't beat a fishing rod and tennis ball, as long as it's close enough and I can manage to cast straight... If not, out comes the trusty old Pirhana (an old MFA boat) to tow the line out and then I reel them both back in. Depending which boat it was, if it was a smaller one, I'd sometimes just tie a line and ball to the back of the recue boat and tow it back in.
My little old MFA Pirhana... bless it...
yup,the "down time" compared to having to ROW OUT to retrieve a boat, and using a fast electric is well...........a "no brainer"....especially if your FIGHTING a current....[:-],I mean think about it,the time spent to row out 75-100 yrds,by the time you get there you have both drifted out 140-175 yrds out,now you have to fight that current to get back in ...no thanks
MO
We use the Aquacraft Hammer electric with a salt water type bait cast reel full of line, but we have a 40 acre lake and its a long way to the boat sometimes. drive out around the dead boat make a 180, then reel both of them back in. If its nose up then the retrieve rubber raft is necessary.
This setup is faster than an aluminum boat and motor most of the time and not near as physical for us old timers. We have about 6 of these in our club and they are used every week to retrieve the gas boats, the aluminum boat comes out about twice a year.
The boat needs some more floatation and some electronics waterproofing, but makes a fine retriever. I have a post on www.modelgasboats.com about it..
mike sr
mike sr
