Output Yokes slipping off shaft? Whats the solution?
Hey guys,
On my nitro rustler w/ steel output yokes the yokes keep slipping off the shaft. Bolts are tight as can be with blue locktight, yet it still slips... is it the shaft that's messed up? Any solutions?
-Brian
-Brian
if the shaft has a flat on it be sure the set scew lines up with it. if the flat on the shaft extends all the way 2 the end of the shaft the set screw can still slide off. try grinding a flat on the shaft right where the set srew will go but do not make the flat all the way to the end.
I have to look at it again... I know that when I screw it in it's on the flat, but I believe it still has the ability to slide off. Would I just file it down a little more where the set screw sets?
-Brian
-Brian
