help with my new g3.0 (make it fit on my rs4)
RE: help with my new g3.0 (make it fit on my rs4)
i have the engine mount but what i mean is i need a different flywheel and other stuff because the one off my fantom fr.15 does nnot fit/
The G3.0 comes with the RS4 Evo+ RTR. If you got this one from an MT then you should be able to go to HPIs site and download both manuals and compare. You may need a different flywheel then what you currently have but I have a feeling the RS4MT and Evo are the same.
NO the g3.0 doesn't come with the rs4 Evo+ but you should return it and get a t3.0 because its the same thing but differnet case says Hpi. I know that cause i called them about the engine echange program and i asked if the g3.0 will fit they said i will but you will be better off getting the t3.0 because it is the same thing and you will have to buy like you said new engine mounts and a new flywheel. You will need the fly wheel from the mt.
UT
Actually TaLaCaTTack the G3.0 does come with the RTR RS4 Evo+. I just bought mine and that's what it is.
Red Man, why don't you transition to an HPI flywheel? It would probably work better and fit your needs. No guarantee, but just a guess. Here's the link to it.
http://www3.towerhobbies.com/cgi-bin...?&I=LXM718&P=7
