Go Back  RCU Forums > RC Airplanes > Twin & Multi Engine RC Aircraft
TF 310 Retract Installation
Twin & Multi Engine RC Aircraft Discuss the ins & outs of building & flying multi engine rc aircraft here.
Old 04-15-2008, 11:10 PM
Texan2
Texan2's Avatar
Default TF 310 Retract Installation
I had to make an adjustment to the main gear mount area in order to get the retract to rest on the mount. I had to cut away with my dremel, directly below the cut out portion, against the top sheeting. Has anyone else encountered this problem? I''m using the recommended Robart Gear.
Thanks.
Also, any ideas on how to get the gear doors to close and open would be appreciated.
Thanks again.
Old 04-16-2008, 06:34 AM
marktur
marktur's Avatar
Default RE: TF 310 Retract Installation
Hi - check the "Cessna 310 Posted" forum. There''s over 105 pages of REALLY GOOD INFO - covering both your questions. This whole thread is a "must read". I pulled the pin and eclip that holds the cylinder on so it would rotate while I got it past the mounting blocks. Then I put in the screws and reinstalled the pin and e-clip.
THanks,
Mark
