Do trucks jump better w/ body on???
the only way a body may help is if your truck was nose heavy, then you could try and get a wing for your body so the air would push the car back while it in the air. But thats may not work just something i thought off. If the trucks rear heavy while going off a jump then you need to put on the brakes just after you truck leaves the jump. But for the most part the body wont correct bad jumping habbids, you need to manaully correct them by either braking or giving it throttle.
CA,
Re: Do trucks jump better w/ body on???
Originally posted by nmtr13
My truck jumps like crap, would the body make a difference...
