SPE 26cc prop size question?
I've used 18 size props and the center hub is the same size as the hub on the SPE26. I'm not getting the RPM's I want and would like to try a 16 size prop, but the center hub is smaller then the hub on the SPE26. Will this harm the motor? Or as long as I don't over RPM it, it well be ok?
IA
If you choose to run a 18 inch prop on it, make it a Mezjlik...18x6. The Zenoah 26 really likes this prop, but I am not sure how this engine compares in power. I would suggest the APC 17x6 to start with
