Hardware for a 60 inch Cat??
Hey Guy,
a couple of yrs ago i bought a 60 inch cat from forabuck off ebay and now i finally have time and money to get it going. I have a G26 engine,tune pipe and header, radio box and radio. the only problem is the running hardware. Any suggestion on what to get for it??? It is a sub drive boat. I'm looking for something between $100-$200
also a good prop too. if you have pictures and links for your suggestions would be great
Aaron
![](http://i234.photobucket.com/albums/ee49/ayates1977/boat.jpg)
![](http://i234.photobucket.com/albums/ee49/ayates1977/boat2.jpg)
![](http://i234.photobucket.com/albums/ee49/ayates1977/boat3.jpg)
Aaron
![](http://i234.photobucket.com/albums/ee49/ayates1977/boat4.jpg)
TN
http://69.49.183.35/ProductDetails.a...uctCode=RH4040
You don't need dual rudders unless you just want it for looks. It will just slow it down and that's alot of hull for a stock engine.
I would just go with Speedmaster single.
ORIGINAL:
I don't see the speed master single?? am i looking in the wrong place?? I would consider going with a single rudder because i plan on making this boat for speed and soon modify the engine.
TN
Try here. http://www.rocketcityracing.com/prod...ategory_id=143
WHH does not sell Speedmaster. I suggested the speedmaster because I used to have an MTI cat which is about the same size as your boat and I used it successfully on it. You could even call Brian at Rocket city and he could set you up with everything you need.
Have you contacted Vern (Forabuck) and asked him what the most successful set up is for this hull?
I run dual rudders from TOPSECRET on my Expresscraft Mti and it maybe lost 3 mph overall...most of the guys here you will find have a racing mentality...duals run awesome...but i am running a qd25ht, and a bonzi bzx4
