Prather 47" Deep V
RE: Prather 47" Deep V
25cc Homie with a big bore carb,water cooled head,wet tuned pipe
Direct drive Running a prather 270 prop runs in the low 40's range not too bad for my first gas boat
The guys in it are 2 Jeff Gorden 12 inch figures witch I dyed and painted the iniforms and helmets to give the boat a more realistic look
I designed the tribal flames in photoshop and the guys from [link=http://www.wickedstickers.com]www.wickedstickers.com[/link] made them for me
thats about it.
thats about it.
ORIGINAL: stempak
I always liked the look of that hull. How does it handle so far with that gas in it? It is a 6o!+mph hull, in nitro form
I love the way it handles, It is a great hull for gas in my opinion.
WA
If you blow your motor up, or want some more performance. Put a modded 231 or 26 zenoah in it, With a CC 2" banded pipe Your boat should handle better two. Your motor is probably making 2hp. A moddified 231 will make around 6hp.
ORIGINAL: stempak
Yeah i plan on puttin a g26 in it once i get this other 60 inch cat going ,but for now I'm just gunna play around with it. I'll have to check out that 231 too
