has anyone ever used the belt cp head for HBK2?
i have a belt cp head i want to use on the HBK2. are there any issues? will i need to readjust the linkages to suit it for the king2. i have a pitch guage. i was hoping that it would be a straight drop in. gotta love those ball links!
RE: has anyone ever used the belt cp head for HBK2?
the only difference I can find between the 2 (other then the shiny links) is the flybar case and arms that screw onto it, but if all you're after just buy these
[link=http://www.ka-planes.com/inc/sdetail/2275]Washout assembly[/link]
[link=http://www.ka-planes.com/inc/sdetail/7331]Swashplate set[/link]
these must be used together, will not interchange with HBK II, just these 3 parts,
[link=http://www.ka-planes.com/inc/sdetail/6062]Flybar case[/link]
[link=http://www.ka-planes.com/inc/sdetail/4865]Flybar paddle control link[/link]
[link=http://www.ka-planes.com/inc/sdetail/2261]Ball control link[/link]
ORIGINAL: nuttcaze
I was looking for a solution of how to get CNC performance W/O risking CNC parts & price at the top end. I've been running these parts for about month now. & can confirm, taken as a set, they’ll drop right in.
What you get for the effort is bearings in place of bushings, & metal to plastic rather than plastic to plastic link joints. After a month’s worth of flying (~5hrs air time) wear if any has been minimal.
The only negatives I see, are one, the flybar center post pivots appear to be no stronger than the original (IMO a high failure point W/ stock setup), and two, the ball screws (particularly the blade clamp ones) are too short & too fine of a thread to be screwed directly into plastic. Would have preferred that they mated W/ a threaded metal insert. But to their credit, to date, I haven't experienced a failure.
Jim
cool. thanks guy. i just finished repairing the head last night and will drop it in the HBK2 tonight and test.
