decent radio??
NY
decent radio??
Hey guys, I have an expresscraft osprey boat with a 30cc gas engine in it. I took the older futaba radio out of it because the battery clip broke and it was just outdated. I put a newer futaba 2 channel radio that I had sitting around and it has the same onboard 4 AA battery setup in it. The throttle works fine, however the large hi-torq steering servo barely moves. I am not smart when it comes to the radio/ electronics thing. Could anyone give me a suggestion or ideas?? THANKS
NB, CANADA
RE: decent radio??
you mean you have switch from an FM to AM Tx and Rx?
if thats the case there should not be any problem.
I am wondering, if the Rx you have put in is limiting the voltage (BEC) and only sending 4.8volts to the servo instead of 6 volts???
Now the standard size servo won't have any problem working on 4.8V but for a 1/4 scale servo however 4.8V is low.
Dan.
Dan.
RE: decent radio??
If the RX has a 3rd channel on it, plug the battery pack into that instead of the normal slot as the BEC with limit voltage. Next, move up to a 5-cell pack instead of the 4-cell. Big servos eat the juice.
AM radios usually aren't the best choice for a gas boat as they're more prone to picking up interference from the ignition system.
HI
RE: decent radio??
Futaba 2.4 ghz would be a good investment, not too expensive and works perfectly and never worry about who is on what frequencie. I think Tower has then for under a 100.00 bucks.
