water cooled exhaust
Old 04-30-2008, 02:46 PM
bigsliks
Default water cooled exhaust
I have a aircooled motor but a water cooled header and pipe, is there any way, not to water cool the exhaust?
thanks
Old 04-30-2008, 04:05 PM
firelite_marine
firelite_marine's Avatar
Default RE: water cooled exhaust
I dont think you have to if you dont want to
Old 04-30-2008, 06:27 PM
Mr.Freeze
Mr.Freeze's Avatar
The only thing you might have to watch for is the silicone couple melting and also heat from the pipe in the hull. Should be fine if you have an open hatch.
Old 04-30-2008, 07:40 PM
bigsliks
So the o-rings won't melt? that I guess is what I'm asking.
what about the manifold will it crack?
what about welding the pipe to the header and the header to the manifold flange would this work?, after getting it tuned of course.
I just see the water pump and hoses as extra stuff that, if it isn't need then why have it.
thanks
Old 04-30-2008, 07:43 PM
Mr.Freeze
Mr.Freeze's Avatar
you might be better off with a quickdraw pipe setup as I think they are welded and use a spring retension system like on a dirt bike. I'm sure some of the other guys will pipe in that run those pipes.
Old 04-30-2008, 07:45 PM
Mr.Freeze
Mr.Freeze's Avatar
here is a pic from there website
ID:	940529   Click image for larger version
Old 04-30-2008, 08:07 PM
mauian
the o rings will melt unless you live where its cold...lol. but yes they will melt, when by accident or vibrations a cooling line falls off, the o rings melt due to too much heat. So either like posted above about a QD or get some lines to the flange if ya have a cooling flange. I forgot you can also wrap it with some plumbers tape from I think Home Depot but the flange on the header O rings will still melt.
Old 05-01-2008, 08:14 AM
jdoug
I run a dry pipe on my water cooled Zen. I've had a little problem keeping couplers on. I got Teflon couplers now, so testing those in a week or so. I haven't had time to make it to the water yet this spring. I think they will hold up just fine.
