PPM - PCM - HRS
PPM - PCM - HRS
Hey guys, i have some questions. In a month, i will have my future 4PK I was browsing a little untill i come along with these parameters. What is PPM, PCM and HRS? I don't have an idea. The 4PK has the ability to change between these 3, but which is most suitable for me? What are the advantages and disadvantages of each one, and what are you using now? Which is the best?
RE: PPM - PCM - HRS
ORIGINAL: Osirisf16
1 Post
RE: PPM - PCM - HRS
PPM - Pulse position modulation http://en.wikipedia.org/wiki/Pulse-position_modulation
PCM - Pulse code modulation http://en.wikipedia.org/wiki/Pulse-code_modulation
RE: PPM - PCM - HRS
ORIGINAL: systemlord
HRS uses Futaba's Spread Spectrum technology, one catch though you have to use all digital servos. If you use an analog servo in HRS you will kill the servo, HRS is Futaba's High Response System which is the only mode that permanently stores your servos fail safe position.
ORIGINAL: Osirisf16
What about the other modes? Sorry snowbl!nd but i don't understand much of this you gave me I need something in simple english first. Can't understand this if i don't even know what is its job, right? [)]
RE: PPM - PCM - HRS
ORIGINAL: Osirisf16
So HRS would be the best choice? What do you mean failsafe position? They are gonna stay in the position the last time were? That's bad if you were in full throttle
ORIGINAL: Osirisf16
http://2.4gigahertz.com/
RE: PPM - PCM - HRS
ORIGINAL: Osirisf16
HRS originally was used with PCM mode, but now, with 2.4GHz in use by Futaba, HRS also exists in the 2.4GHz signal transmission as well.
